I have a leaking flex coupling in a vertical line. The leak is due to a small hole in the coupling. It is the kind of coupling with rubber and two metal clamps, one at each end. I've loosened the metal bands on the old flex coupling to try to replace it, but it won't budge after the bands are removed. So, I assume I would need to cut the rubber coupling to remove it. However, the pipes that it connects also won't move, and I'm guessing that there will be little gap between the pipes to install a new coupling after I remove the old coupling. So, how do I get a new flex coupling in there?
Currently, the options I see are (1) cut the old coupling out, and hope I can somehow force a new coupling in with the small amount of available space. But I'm not optimistic I'll be able to do it. The vertical line leaving the coupling then goes into a 90 degree elbow and runs only for a very short distance, about a foot, before entering the ground. So I don't think I'll have much play to make space to get a new coupling in there. (2) cut the old coupling out, cut the elbow off, attach a new coupling to a new piece of pipe, attach an elbow, then glue things back together. But that seems like more work than needed to just replace a coupling. (I need some kind of coupling as it adapts from 1 1/2" to 1 1/4") (3) Is there a way just to fix a small leak in a flexible coupling? Some kind of glue that could go in the hole? This coupling is outdoors in a sump pump, so a small leak is no issue and will not cause damage.
Other ideas?
