Need some advice on installing a dishwasher.
- Cabinet on the left measures 24" in width exactly. 34.5" height below the counter and 24" depth.
- Cabinet on the right is the sink. There is electrical and garbage disposal already installed underneath.
Questions:
- Is it going to be too tight for a 24" built-in dishwasher? Bosch seems to have the most narrow options (23.5") but instructions state it needs 6" clearance if placed against a wall. Other brands say 2" clearance against the wall. I'm not sure why clearance is needed. Is this just for humidity reasons? Since you can't see the wall, would using a sealant work?
- Another possible clearance issue: If we do a 24", is supporting the countertop going to be impossible or is there a solution there? There's not much space to add 1x4 or 2x4 brace.
- Or should we opt for an 18" built-in and add a 6" base cabinet box at the end with a cabinet filler at the front? Would this support the countertop? And would this be easy to DIY as I'm not finding many pre-made 6" boxes?
