Background
I have an old home from the 1920's. It has a faux fireplace w/ no attached chimney. It appears to be originally added when house was built.
There's a 4" galvanized metal cap on the wall below the mantle. The cap has no screws to remove it. I'm guessing it's similar to this one: https://www.homedepot.com/p/Master-Flow-4-in-Round-Duct-Cap-DC4/100396932
More pictures and video at https://imgur.com/a/unknown-wall-cap-plug-underneath-faux-fireplace-z26erOS. This includes a video I took from a camera scope that gives a view behind the cap/plug.
Questions
  1. What this cap/plug is for, i.e. why was it added? I took a camera scope to look behind the cap and there's no duct work from what I can tell so unclear what the purpose of it is.
  2. How best to remove it? My goal is to put fish some low-voltage cabling through it. It seems firmly attached but not sure if that's just the paint.
Faux Fireplace Wall Cap
    Is this an outside wall? If so, perhaps there originally was a wood stove or similar item in this location venting straight out the back and they capped the hole. Commented May 14 at 1:42
    Yes, it is an outside wall. A wood stove would make sense. I didn’t see any artifacts of that on the scope camera but maybe the angle wasn’t right. Thanks!
    – ravishi
    Commented May 14 at 5:02
