Is the height of my drain going into the wall too high and I’m screwed? What should I do?
Or this? Can the garbage disposal outlet be lower than the building drain inlet?– isherwoodCommented May 8 at 18:06
Or this? Disposal pipe level or slightly below stub out– isherwoodCommented May 8 at 18:07
Or even Is it ok that a new deeper sink disposal line is the same height as drain line? or Drain and disposal outlet same height??– isherwoodCommented May 8 at 18:09
Add a comment
1 Answer
Yes with a drain at that height you will always have water in your disposal.
Either go without a disposal, or have the drain lowered.
A last suggestion that is probably the least popular, is a sink that is not so deep.
I know of no disposal that has a discharge port that high on the unit.
There are the sinks with a smaller, shallower bowl for the disposal so it ends up at similar height to a drain from the regular depth sink. But of course this problem usually comes after choosing a massively deeper sink in a remodel that the homeowner wants, so lowering the drain in the wall is the best option to preserve that presumably new purchase.– EcnerwalCommented May 8 at 16:53
