So for context: we had radon in the house so we had a fan installed to suck the air underneath the basement slab. When they drilled the hole, they found water under our slab. The guy said that it was probably going to be okay since there was still some space for the air to go through. Fast forward a couple days after the installation, the fan made a really high-pitched noise and when I removed it the water level was really high it was actually touching the slab so there was no space for the air.
We decided to install a sump pump to remove the excess water, and the water level definitely has lowered. (The sump pump is about 3 feet next to the radon fan) What happens now when we start the radon fan, for a couple of hours it will be fine, no unusual sound, but after 4-5 hours a gurgling sound appears, like some bubbles of air are moving under our slab. When I remove the radon fan to inspect the hole, I can see the water is a little bit high, but there is still space for the air to move (maybe 2 inches between the water and the slab) . When that happens, I turn off the radon fan for a couple of hours, the water lowers a little bit more, and then I turn on the radon fan again, and after a couple of hours the water level increases and the gurgling sound comes back.
I suspect that the radon fan actually sucks the water from the ground over time and creates a pressure differential strong enough to prevent the water from going to the sump pump. That would explain why turning it off removes the problem for a couple of hours, but I'm no expert. I talked to the plumber that installed our sump pump, and to the guy that installed our radon system, but both of them don't know enough about radon or plumbing to help us. In my area there's no other radon mitigation companies... That's why I'm posting here because I have no idea how to fix this. Any ideas?
