I'm trying to mount a few hose reels around the house. I'm assuming next the main breaker and above the cable stuff should be good as there is drywall after the concrete block and I assume the wires would be in there. The water main is where I'm most concerned as there is just that one concrete block that it is going into and I don't know where it goes from there.
    Most concrete block, stuff goes straight though, from inside to outside, as that is the easiest. Drywall on wood studs inside might be different, so know what is inside.
    Commented Apr 28 at 22:29
  • Yea I’m going about 1 3/4 in. The main water supply had no drywall behind it and I the other side of the wall has no pipes so I assume it’s in there. Don’t know if it goes sideways. Straight up or whatever
    – robl45
    Commented Apr 28 at 22:42
  • Odd. You know how much space is inside blocks, so hard to think they would go in blocks.
    Commented Apr 28 at 22:53
  • use strong magnet to find out
    – DIY75
    Commented Apr 29 at 0:09
  • This can depend on where you are located. In the southeast plenty of times the water lines go in the wall and down through the concrete slab.
    – RMDman
    Commented Apr 29 at 0:20
