I've been reading up on whether I can lay LVPF over an already tiled basement, and the consensus seems to be that I can so long as the grout isn't too wide/height differentiated and the ground is level.
I'm reading some LVPF brands and see that some say not to lay it over tile if it's applied over concrete below grade. I have no idea what's under the tile in the basement. I would hope there's some kind of vapor barrier and the tile on that if it's directly on the cement slab. But I have no idea.
Should I be worried about this? Could I mitigate it with an extra vapor barrier or something? I'm doing the poly sheet taped over the floor for 48 hours test now to see if there's any vapor leakage. But it's generally pretty dry down there.
EDIT: Added photo of where the tile meets the door frame and the unfinished laundry room that has what looks like painted linoleum.
