I've got a Goodman forced air gas furnace. It's about 17 years old. It recently tripped the flame roll out sensor. About 2 or 3 weeks ago I replaced the ignitor on this unit, and it's been working fine since then.
So I took the cover off, reset the roll out sensor and ran it through a cycle to see what's going on. Sure enough, two of the four burners aren't going into the heat exchanger, and are burning outside - and are therefore tripping the roll out sensor. Bottom and 2nd from the top burner.
Anyway, this seems like a classic failed heat exchanger. The inducer fan seems to be working fine. Two burners are working properly, which would seem to indicate that the vent is fine. I also went up on the roof also and inspected the vent - looked fine, but has a difficult to remove cap on it, so can't see much
So I ordered a new heat exchanger and pulled the old one out today.
I've looked the old one over very carefully, but I can't find any damage. Tried stuffing rags in the outlets and hit it with the air compressor. Tried filling the tubes with water. No leak that I can see/hear/feel.
I'm reluctant to install the new part if I can't a defect in the old part. Any suggestions on what could cause this behavior if the heat exchanger is ok, inducer fan is working, vent seems fine?
Edit - took a close look at the burner tubes and gas jets. They all seem fine.
