I was all set to replace the three-prong electrical outlet for a dryer. The plan was to change the old flush-mount with a jbox outlet and extend one of the hot wires to an adjacent jbox that holds a current relay switch to run a booster dryer vent blower when the dryer is running, per this diagram:
I bought a length of 10 gauge wire, thinking that should be sufficient since I'd never encountered anything larger than 10awg for a simple dryer outlet. After removing the cover to the existing outlet, I discovered this:
I've never seen wire this thick in a house. The outside diameter of the black wires are 0.25", which means it's what...4awg! OK, then. but I don't think I can wire a 10awg to the end of one of these behemoths, through the current relay switch and back into the outlet.
What's the correct approach for doing this right?
Edited to include response to several comments.
Thank you, everyone, for your comments. I'm collecting my replies here.
To @Ecnerwal's answer
Indeed, the breaker is 30A.
I can see very little of the cable jacket due to the conduit. From what I can see, there is no lettering. Not enough of the actual cable is exposed where I can measure it, hence my measurement that included the insulation with calipers for a rough guess. I know this isn't the best method and is short of taking everything apart.
The house was built in 1972, so even thought the wire is "banned" (@crip659) it was likely to code in 1972. I'm exploring to find out what it would take to retrofit this with a ground at the outlet as replacing the entire wire from breaker box to outlet is cost prohibitive. Even so, I'm getting mixed information, from both pros and DIY'ers, on just how important a ground is.
After searching, I can't find a 3 prong 240V/30A CO/ALR rated receptacle. Plenty of 120V/15A CO/ALR rated receptacles.
These connectors are new to me. They look to be a way to, essentially, splice the existing aluminum, wire to an equally rated copper wire. I don't have much room to work with and I'm hoping to minimize the amount of rework on the existing outlet.
I'm still with you. This makes sense so far.
I have the tools needed for this. Will need to research a little more to be sure I have the corrects torque specs.
I don't quite understand this, and don't have a good visual of what such a "disconnect" would look like. I'm familiar with disconnect boxes for things like A/C or hot tubs, but I usually have, comparatively, a lot more extra wire to work with. This would, presumably, require the removal of an appropriate length of conduit to expose more of the existing wire that can then be worked with inside a disconnect box.
A couple of other comments/questions about this situation.
First, I'm also getting mixed information about just how "dangerous" this aluminum wiring is, again, from pros and DIY'ers. Some say it's fine, others leave me in fear of the wire spontaneity combusting in the middle of the night. Is there a way to test aluminum wire to determine if it's a danger?
Second, another idea was to use a 3 prong 240V/30A extension cord such as is used for RVs and EV level 2 charging. I could then splice into the extension cord to access the hot wire I need to pass through the current relay switch. That would be a crude fix. What I would actually do is remove the female end of the extension cord, run it to a jbox with a suitable 3 prong outlet. The rest of the solution - an adjacent jbox to house the current relay switch, etc. would be according to my original plan.
Edited to include view of conduit
