I've got zinc strips on my tar shingle roof. They are all curled up, tearing loose at the ends, and lifting up the shingles so I need to remove them. What do I do with the holes from the nails that were holding the zinc strips on? Put a fresh nail back in the hole to plug it up and roof sealant over it or just sealant over the hole? Will the nails work loose and lift the shingles if I put them back in?
Reasonably sure the zinc strips were added after the shingles were already installed so those nails aren't needed to hold the shingles in place.
