So my house was built in 2023 using wood studs. Tried mounting a tv I’ve mounted a 1000 times in previous homes and found that as I was drilling the nail into the stud the stud started to push the drywall forward. Any thoughts/recommendations?
    Need far more info on this one. As you have it stated, the situation is impossible.
    – RMDman
    Commented Apr 23 at 0:19
  • Are you mounting to an outside wall that is block by any chance?
    – RMDman
  • Did you hit wood or metal? were you expecting wood?
    – Jasen
    Commented Apr 23 at 1:34
    how do you drill a nail into the stud?
    – jsotola
    Commented Apr 23 at 3:33
You probably hit an area where they didn't fasten the drywall properly to the stud so the drywall pulled away a bit. Another possibility is you hit a nail plate and the drywall pulled away. If you're going to continue to move, put the TV on cabinet :-))
