Can anybody figure out where a C-wire would be connected in this old forced air electric furnace? How do you test it with a multimeter to make sure?
- Big 240V cables are at
1 (pink circle)
in picture; ground wire is just below, kind of underneath, connected to white wire going to motor (not shown, towards left of picture) - 240V to 24V transformer is at
2 (pink circle)
with two yellow cables coming out on top for the 24V circuit - R cable for the 24V circuit is in a
red circle
and connects directly to the "R" screw used by the thermostat. The thermostat orange wire is currently connected to... nothing. Don't know why. Ignore that. There is also a floating gray cable containing 3 wires connected to nothing on both ends. Ignore that too.
There are 4 diagrams inside the box, but I think this is the correct one. Other diagrams seem to be for different outputs (kW) and voltages (240V or 208V).
Obviously trying to connect a smart thermostat (Ecobee Premium) to a very old furnace. The irony!
Thanks! 😉
