I recently bought my first house and have been investigating the GFCI fix to branch circuits that (due to installation date) do not have equipment grounding conductor installed. My receptacle boxes are teeny tiny and don't fit modern GFCI receptacles. I started looking into GFCI breakers to make my life a lot easier, but when I looked in my panel, I saw something unexpected. It appears that I have (running to several bedrooms) a pair of 15-amp branch circuits that share a neutral, and have the hot conductors on separate phases. They are currently plugged into a dual-pole AFCI breaker:
Like I said, I was hoping to add GFCI protection to each of these circuits at the panel box. However, I haven't been able to find a 2-pole, dual function (AFCI/GFCI) breaker from Siemens. Does anyone know if these exist? If they don't, is there a particular reason why not?
Any suggestions what to do here to keep AFCI protection and add GFCI protection to this weird circuit?
