I have limited experience with shower repairs. Recently, I've noticed that the grout/sealant between the tiles on my shower floor has begun to peel off, and I can see water seeping between the tiles. I would like to understand the necessary steps to address this issue so I can research each step further. Should I remove all the existing sealant, reapply grout, and then reseal? Or is resealing alone sufficient? Thank you for the help.
Floor1
floor2
  • If it's built properly, the waterproofing is below the tiles. So you're just regrouting - it's not a sealant.
    Commented Apr 6 at 16:16
  • Still, if the grout is failing, there may be some movement. OP, do you have grout, or caulk, at the edges of the shower floor?
    – Huesmann
    Commented Apr 6 at 18:33
  • That loose piece of grout looks way too big for the tile joints. Did they perhaps use sanded grout in an application that should have been unsanded, according to the joint size? Commented Apr 6 at 19:20
  • How old is it? Do you have any gaps filled with flexible or silicon grout? Commented Apr 6 at 20:00
  • I just recently moved into the house, i believe it is around 2 years old but don’t have more info than that. There is no caulk, it’s all grout. I don’t know type of grout it is.
    – Legyptiano
    Commented Apr 6 at 21:12
