This section of the wall (it may be plaster) was removed to install a French drain which you can barely make out in the picture.
I'm thinking of using tapcons and glue to adhere drywall to this section since there's not a lot of room to work with for furring strips. I'm concerned about humidity given the French drain, although the back of this wall is not exterior; it leads to a closet.
Other than drywall, what other alternatives should I explore?
    Looks like it was previously simply glued to the block?
    – Huesmann
    Commented Apr 3 at 13:13
  • I'm not clear on what you're calling a "French drain". The term simply means a gravity-operated drain to another part of the property. Where is the moisture likely to be here?
    Commented May 3 at 13:20
  • What kind of finish is currently on the wall? I agree, it looks like some drywall had been glued up before.
    Commented May 3 at 13:47
  • There is a French drain installed under the steps. You can kind of see it by the first step of the staircase. Agree with the glue, will attempt to do that.
    – Guest
    Commented May 22 at 22:12
I would make very thin furring strips, just for support, or use a metal mesh. Then use the traditional plastering method of sequential layers of hot mud, adding 1/8" to 1/4" at a time until it's at the same level as the rest of the drywall. Then a final layer of lightweight joint compound.
