I need to patch the subfloor after moving the plumbing from under the floor to the wall, in the bathroom. To support the new OSB patch, I've added floating 2x4s and now plan to put the board down with 2" screws and PL400. Now I'm sure you see the 1/2" gap between the old and new board at one spot.... what can I do about it? I don't plan to cut a new board but here's what I'm considering :
- Fill in some foam to ensure seal from underneath (prevent air, moisture, or bugs from passing through) OR
- Fill out the gap on the board first with Bondo and then lay it down. What would you all recommend?
PS: I plan to lay down LVP (20 mil wear layer thickness) directly on top. Pictures : https://imgur.com/a/Ijodslm
