I know it's not the bulb or the ballast (it's a starterless ballast), I've swapped bulbs to a different unit in same circuit, the bulb works in both of them but both don't work at the same time, I've even tried a different bulb in the same connections, only one works at once and not always the same one, no clue here, any ideas?
    Often the carriers that the end of the bulbs fit in are faulty. Either the small tabs get bent or a wire comes loose. Check those.
    – RMDman
    Commented Mar 16 at 15:05
  • Don't think it's that as both of the individual units work, just not at the same time Commented Mar 16 at 19:42
  • Are these the standard 4 foot fluorescent fixtures? If so, just change out the fixture. Or better change to the new LED fixtures.
    – RMDman
    Commented Mar 16 at 21:52
  • Six foot fittings, might be an option, just more hassle if it's not needed Commented Mar 17 at 17:35
