Is it okay to remove a partition wall that has its top plate going under the I beam of a load bearing wall?
Would I just cut the top plate flush with the studs of the load bearing wall?
The red arrows indicate what I want to remove. The yellow lines are where the joists are located.
https://imgur.com/a/d9tIoAV https://imgur.com/a/6i9aA9d
I want to remove the doorway part from the partition wall between a shower and main part of a bathroom. I only want to have part of the partition wall remaining so the ceiling is continuous from the main bathroom into the shower and the wall is continuous between the shower and bathroom. I've already removed the door header and jack studs.
The steel I beam ends right after it intersects with the top plate of the partition wall. There is a duct going parallel with the joists almost directly over the partition wall after the beam ends. One of the pictures shows this.
  • What is the purpose of the steel beam? By your pre-edit question, it sounded like the beam stops short of that door opening in the bearing wall. If it's not a header for that opening, is it relevant to something on the other side of the back wall? Without an understanding of what exactly is going on, it seems reckless to offer an opinion.
    – popham
    Commented Mar 9 at 7:34
  • @popham - The other side of the wall is a family room. The bathroom and family room are on the bottom level of a tri-level on a concrete slab.
    – easyquiz
    Commented Mar 9 at 12:45
  • It sounds like a carrier beam hidden in the ceiling in place of a lengthy missing chunk of bearing wall. The concrete slab seems strange for you to have mentioned. That's a soil supported slab that you stand on looking up at the beam? There's not a slab on top of the steel, right?
    – popham
    Commented Mar 9 at 14:11
  • Yes the slab is on the floor not above the room.
    – easyquiz
    Commented Mar 9 at 14:34
  • If it isn't obvious that the partition wall can safely be removed I'm willing to pay a structural engineer to look at it if that's recommended. I was hoping it would be obvious to someone online with a trained eye.
    – easyquiz
    Commented Mar 9 at 14:37
