I'm looking to add some shade and character to our backyard patio and was thinking of adding a pergola and have some questions about proper anchoring.
I was thinking of using 4x4 or 6x6 lumber for the post and crossbeams.
I wasn't going to install a traditional pergola roof. Instead, I was thinking of attaching a sun shade to the posts that can be removed after each use or some sort of retractable shade cover.
Here's a rough sketch of the plans
Since there is no traditional pergola roof, Can the post anchors be attached directly to the concrete slab, which is 8" thick, or am I just being a noob and footers should be installed?
I'm not set on this idea, but was researching how-tos and don't want to install something that is unsafe.
    6' is going to be too low FYI Mar 6 at 15:50
  • That's my fault. The 6' high was meant to be the height of the house. I was planning on building it 8' tall. Mar 6 at 16:41
If you attach your post to your 8" concrete patio, you have four key things to consider:
  • Local building code concerns
  • Lateral load
  • Uplift load
  • Soil concerns
Local building code I was surprised to find that my local building & planning department had requirements for a simple pergola. "Gazebo/pergola type structures are usually not of typical “light frame construction” and are treated as pole construction projects that require “structural engineering” done by an Idaho licensed engineer. Height restrictions may apply in some areas."
Lateral load Setting your posts down into the ground gives your pergola a lot of ridigity when it gets pushed sideways from wind. I haven't seen any plans for pergolas where no pier or footing is recommended.
Your rough sketch shows three parallel posts. If you don't set your posts down into the ground to secure them, these posts could tilt sideways with wind load. Consider adding "knee braces" where your posts connect to the horizontal beams. For knee braces, see this answer.
Recommendations from a sun shade company To get an idea for securing posts for a simple pergola, a sun shade company suggested setting 6"x6" posts into the ground at least 36", with concrete surrounding the post (30" diameter):
Footing depth should be a minimum of 36 inches deep and 30 inches square. For example, if your post height is higher than 8 feet, we recommend a hole depth 40% of the height above ground. Link to PDF This sun shade company noted they are happy to take calls, so you may consider asking your future sun shade supplier what they recommend.
Beware of freezing In a great post by Piffin over at FineHomeBuilding, the results of freezing and tilting posts are discussed:
...look at it this way, if the ground heaves and the slab tilts a quarter inch, you may not notice it much underfoot, but if that tilt plays into the column at ten feet high, that could result in a 3 or 4 inch lean, depending on how everything is tied together.
If you have minimal or no ground freezing, this is less of a concern.
  • Thanks @CharlesW! Your rough sketch shows three parallel posts. If you don't set your posts down into the ground to secure them, these posts could tilt sideways with wind load. Consider adding "knee braces" where your posts connect to the horizontal beams. For knee braces, see this answer. So, ideally, it seems that footings for each post and also add knee braces would the proper way to go to ensure long term structural integrity. I may have to look into how to create footings through the patio, or an alternate answer. My formatting is trash, sorry lol Mar 6 at 17:33
  • I'm unsure if it would be called a "footer", as you would be burying your post and surrounding it with concrete. See this answer for tips on setting a post. And see this answer for links to more pergola / post / concrete questions.
    – CharlesW
    Mar 6 at 18:39
  • Do you mind accepting my answer? I'm a noob, but I think I answered it.
    – CharlesW
    Mar 6 at 18:41
  • I think I would have dig out the holes in the concrete slab and then install the posts there or dig out and install a footing to anchor the post to Mar 6 at 20:26
