We have a well system that is currently set up in this order. We don't have many problems out of it other than the typical issues such as hard water, sediment (occasionally), and multiple demands (shower, washer, and dishwasher) causing low pressure. It is plumbed in a Tetris fashion with pipes going every which way, flowing to the left then back to the right. I want to streamline the plumbing and place all the water devices in the correct order of operation. While doing this I plan to move to the max diameter pipe 1 inch that I can use for each device to increase the flow throughput.
The well is 600 feet down, or that is what I am told, we have very hard water, and we have had the water tested which showed no issues or contaminates.
The current setup is: Well Pressure Tank > 100 Micron Spin Down Sediment Filter > Holding Tank > 5 Micron Big Blue Filter > Water Softener > Water Heater > House (As a side note we did use a 50 Micron Sediment Spin Down Filter but it kept getting clogged quickly and even more so after it had rained. Therefore I had to move up to the 100 Micron to keep the flow going. I also have another Big Blue filter as a spare that I could substitute somewhere in the system. It can be a 5, 20, 50, or other level filter that can be installed.)
My question is does this seem like the correct order of operations for treating well water? Do I need to move, add, or remove anything?
