I have a closet door frame that is off - specifically it is not the same width all the way across at different heights. I’d like to know what might be causing it, everything from benign to concerning.
Here are the widths at different heights: Bottom - 29 3/16” Middle - 29 1/8” Top: 28 15/16”
Should I expect that the widths be the same all the way? What could the inconsistent widths indicate?
In the picture, you can also see clearly notice the gap between the door and frame also varies. On the hinge side, the gap is wide towards the middle top, but almost non-existent at the bottom.
