I'm having problems painting a ceiling. It was already painted, but I decided to freshen it up (which I regret) as I was painting the walls. I get alternating patches of a light roller texture and completely smooth regions. This wouldn't be so bad but they are extremely irregular and very easily catch the light. I don't have problems with lap marks or anything else, just these weird smooth vs textured patches. The texture result I don't mind but the angled lighting makes it seem patchy. See photo: textured to left, smooth to right. This is actually white (photo has wrong colour balance). It's not clear from the photo but the texture is pock-marked (like the moon) not drippy, like a meringue.
- I Sanded in medium and fine sandpaper before applying;
- I washed the surface down with a detergent and let it dry;
- I washed it again with clean water and let it dry;
- I used a high quality trade vinyl matt emulsion;
- I mixed the paint well before applying;
- I used a clean 9" roller with fabric (of some kind);
- I made sure the roller was smoothly and evenly charged with copious paint;
- I was careful not to over-roll drying paint;
- I applied light pressure;
- I kept a wet edge;
- I rolled in one direction only, away from the light;
- I've applied two coats (since last time I sanded down to start again).
I didn't apply any skim coat because the ceilings were smooth before I made the mistake of trying to paint them.
I still get the result in the photograph. Any advice? Am I doing any of the above wrong, or not as well as I think I am? As you can see above, I have tried doing my homework in advance, but to no avail, it seems.
I've painted quite a lot in the past, including walls with the same setup, and I've used the same paint (from the same tin) on things other than the ceiling, largely without issue.
The main decision to make at the moment is whether I need to start again (again) or if a third or fourth coat would fix this issue? Because:
- I know a lot of texture issues can only be fixed by starting again, but;
- If I don't try adding more coats, I will never know if that's the answer.
