I'm a complete noob, but I'm hoping to learn!
I've purchased 2 wooden slabs that I had the carpenter cut into 4 long shelves. They're cherry, and heavy. But I think they look great.
The gentleman I purchased them from suggested that I sand them down and then apply either Hopes Tung oil or Odies Oil. He was adamant that I don't apply a finish, but instead one of those oils to allow for the original wood markings to really pop.
Here's why I've come to you all!
Do you also suggest Hopes Tung oil?
Do you suggest the Odies instead?
Do you have a suggestion on how to best sand these? We have a power hand-sander, but what level of sandpaper would you suggest to get a nice texture for in-home shelves?
Any tips to make this process less tedious?
Here's the part I'm least excited about: We want to hang these on the wall and I'm severely overwhelmed on how to fasten them to the wall correctly.
What should I be looking for to hang them? I was thinking a simple "L" shaped bracket screwed into the wall, and then the wood. Probably 3-4 per shelf.
Is there a specific brand, weight class, etc I should be considering?
I have a Black and Decker old stud finder, but it seems unreliable. Any suggestions there?
what length screws or type of screws should I use?
Each shelf is about 35 lbs.
Any, and all help is greatly appreciated! I'm not in over my head, I know I can do this with your help!
