I'm attempting to change out a leaky water supply hose on my bathroom sink. Unfortunately, while I was able to disconnect the hose from the water shut off valve, none of my tools are small enough to disconnect the portion connected to the faucet. Looking online, the recommendation seems to be to use a basin wrench but I bought one and it doesn't fit in the tight space.
Anyone know how I can unscrew the hose from the top where it connects to the sink?
It appears like this person had a similar problem: How can I fasten nuts in narrow places when installing a faucet?
But I was unclear what the solution was in that case.
Edit 1: To clarify, sink is undermounted
Edit 2: Photo of Top
Edit 3: Faucet removed. Thanks for help so far. However, even with the faucet removed, I still cannot seem to remove the hose. Does anyone know from looking (picture below) if this is integral per the comments or do I just need to work it harder?
