I'm looking for recommendations for coating a kitchen floor. The floor in question has a plywood subfloor, with 1/6" self leveling compound on top that has hairline cracks, and some epoxy coating on top of that which also has some hairline cracks. The floor is pretty level, but it flexes slightly, hence the tiny cracks. Would elastomeric paint work in this case since it is waterproof and flexible? Perhaps there is some other option that would work? I'm hoping to avoid planks since they would raise the surface higher than the adjacent flooring.
Thanks
hairline cracks
    vinyl flooring might be as good match here if your budget is constrained.
    – Jasen
    Commented Feb 20 at 6:23
  • @Jasen Yeah, but I read sheeting is pretty difficult for diyers, especially complicated layouts like mine. If you meant vinyl planks, I'm trying to avoid raising the surface much more with planks. I figure some kind of paint would be likely cheapest anyhow. Commented Feb 20 at 15:04
    Yeah I meant sheeting, you'll need a helper. I had good success by following the instructions. I used a 1m length of 100mm PVC drain pipe as a roller.
    – Jasen
    Commented Feb 20 at 19:18
    Vinyl sheet or marmoleum won't add much height. It's tricky to DIY but not impossible.
    – KMJ
    Commented Feb 20 at 21:12
  • @KMJ I'm sure that would work, but I think elastomeric paint would be effective at filling the hairline cracks as well as being cheaper, faster, and easier, though possibly somewhat less long lasting. Commented Feb 21 at 3:51
