I have a 10x16 shop that is 65ft from my panel I want to run power to the shop for a computer a air conditioner which I’ll put on its own breaker since in the winter I will use a heater on that plug. I will also have 5 other plugs and 2 lights. The plugs I’m using are 20A 125V. What kind of wire do I run from my panel in my shop to the other panel.
  • "20 v 125 amp"? I don't expect you're running an A/C or heater on low voltage so I assume you mean 125 V, 20 Amp?
    – DoxyLover
    Feb 19 at 5:59
  • Probably 120V 125A Feb 19 at 9:36
    What other loads besides the computer, AC, and general lighting will you have in your shed? Feb 19 at 12:43
