9
I was replacing three old switches with two new switches a timer. The prior owner's install was as follows:
  • White wires all bundled
  • One black wire (hot) running across all three switches Original wiring with one of the black wires removed from the first switch
The switches control two lights and a fan. From left to right A = Fan light; B = Fan; C = Shower light
New switch: https://www.lowes.com/pd/Eaton-Single-Pole-White-Compatible-with-LED-Rocker-Light-Switch/1001438232 New timer: https://www.lowes.com/pd/Eaton-Digital-Countdown-Lighting-Timer/1002943550 (For some reason, the website doesn't show the neutral wire available on the timer, but there is one on the actual device.)
Here's what I did (using all new wire nuts):
  • Cut the black wire that had run across all three switches and pigtailed those connections to the new switches from a wire nut. These run to the top terminal for each switch and the black wire on the timer.
  • Pigtailed ground and grounded everything with bare wire
  • A: Red to the fan light to bottom of a new switch for the fan light
  • B: Black to fan attached to red timer wire; Pigtailed a white wire from the neutral bundle to the timer's neutral
  • C: Black to the shower light to bottom of new switch
  • Reordered the switch positions such that original positions left->right A B C; new is C A B.
Both of the new switches operate the reverse of my expectation with the off/on positions reversed. The timer operates as expected. What should I have done differently?
These images are with circuit on and new switches with hot on top and no voltage on bottom terminal. (Also confirmed with multimeter.) enter image description here enter image description here
In this orientation, all appliances are off: enter image description here
  • all a switch does is it connects two wires together ... for example the left switch connects the red wire to the black wire ... the neutral wire is not involved in any way
    – jsotola
    Commented Feb 16 at 18:13
  • 9
    ... TOP ... Not doL.
    – Mazura
    Commented Feb 17 at 2:41
  • I really don't like saying this, but OP badly needs to practice his screwdriver technique: as well as being unsightly those damaged screwheads will end up cutting somebody (I have a scar on the palm of my hand from something not terribly dissimilar). Commented Feb 17 at 11:36
  • @MarkMorganLloyd - the screw heads are still completely smooth. The coating on this brand is just really poorly applied and doesn’t play well with any contact from a screwdriver. I won’t be buying this sort of face plate in the future. You can tell how bad the coating is if you look at the perimeter of the heads where the coating is coming off just from being inserted into the holes. Commented Feb 17 at 16:22
    @josephorapronobis I'll take your word for it and I'm sorry to have criticised your level of skill and care. You might find that you can make a suitable mix of coloured lacquer with pots (not sprays) of enamel from a modelling shop, but I'm reminded of the 'photo retoucher's trick: it was easier to hide a defect using the right shade of grey than trying to match the exact colour. Commented Feb 17 at 18:33
18
This screen shot is from the Lowe's link you provided:
Image of the switch with an arrow pointing to the word "TOP" embossed on the yoke
Take a look at your switch. I'm willing to bet that it says "TOP" at the bottom as you've installed it.
Unscrew the switch from the box, turn it over, screw it back in.
  • 9
    Even if this had somehow not been the problem, it would still be the solution :) Commented Feb 17 at 23:18
11
TL;DR Turn the switches around
With traditional toggle switches, a regular (not 3-way) switch will have embossed "ON" and "OFF" which tells you how to orient the switch. However, a Decora style switch normally has no external indication of proper orientation.
There are no standards in switch screw locations. I picked the first Decora style switch I could find on the Home Depot web site. The Leviton Decora 15A Single Switch has a picture which clearly shows screw terminals on the right (when looking at the front of the switch) and ground on the upper left. Based on your pictures, your switches appear to be similar, at least in screw configuration.
Leviton
So turn it "upside down" and it will actually be "right side up" and solve the problem.
I just checked the link (didn't notice it before) for your actual switch, and it has the exact same configuration as the Leviton. See the pictures on the Lowes' web page - ground screw top left, hot/switched hot screws on right. Flip it!
Note that with a simple (not 3-way, not "smart", etc.) switch there is no difference between the two main screws. So putting hot vs. switched hot top/bottom or bottom/top makes no difference.
