-1
I have about 20 ml of sulfuric acid I saw in a similar post that baking soda could be added to stop sulfuric acid from evaporating I was wondering if I put baking soda in a glass container and pour the sulfuric acid in then dilute with water if any reactions would occur I know it says to add the sulfuric acid to water just not the other way around but I'm trying to be extremely safe I almost burned my house down this weekend :P
  • I am not sure if this qualifies as DIY. Feb 12 at 5:28
  • It's definitely DIY, but it's not Home Improvement... Also, there's no question, there are no actual sentences...
    Feb 12 at 12:52
    I’m voting to close this question because it's not about Home Improvement within the scope of what's on-topic.
    Feb 12 at 12:52
  • Note that "sulfuric acid " doesn't say anything about how concentrated it is....
    – keshlam
    Feb 12 at 15:22
  • "I know it says add the acid to water, BUT I'm trying to be extremely safe so I'm ignoring good advice" and "I already had an accident so my judgment isn't exactly proven reliable here". <------ things trolls say Feb 13 at 19:21
If you add baking soda you don't have sulphuric acid anymore. You'll have sodium sulphate, carbon dioxide and water.
Sodium sulphate is a salt, and will likely show us as crystals during the neutralization. It's more or less harmless compared to sulphuric acid. Don't eat it, and don't inhale it.
For 20 ml I'd probably just dilute it in a bucket of water and pour it out...
    "dilute in a bucket of water" is right - "dilute with water" wouldn't be. Pouring the acid into copious amounts of water means the water absorbs the large amounts of heat generated, while pouring water into the acid would be a bad idea (e.g. if there's 20ml left in a 100ml bottle don't be tempted to add water to the bottle). Once diluted it could be neutralised with bicarb if you wanted
    – Chris H
    Feb 12 at 13:18
I would just pour it onto dry, bare soil and then spread baking soda liberally on top of it (a tablespoon plus). Leave for a few minutes and hose it down.
Otherwise you risk it spurting onto your face.
