I had a Flood in my basement and used a portable sump pump and hose to pump out the water for several days. The basin is about 2 feet deep with some gravel at the bottom.
Once i finally got the water out to the level of the gravel, I shut off the portable sump pump and installed a new sump pump with check valve.
After a few days, the basing keeps slowly filling up to about 6-8 inches. The float trigger for the new sump pump is about 10 inches from the bottom.
With so many dry days, why does the basin keep filling up with water? Do Sump Pump basins always have a certain level of water in them? Is this normal?
