Recently moved into a new apartment and noticed this ceiling light strobes when I flip the switch. When I took the cover off, this was underneath which I wasn’t expecting. Any idea how to stop the strobing? Wanted to crowd source before reaching out to landlord
Appreciate any help!
  • You just moved in. The lights aren't working properly. Contact the landlord ASAP. What's "crowd sourcing" going to buy you other than spending more time with annoying lights?
    Commented Feb 9 at 20:03
  • Is the light on a dimmer or other special switch? Commented Feb 9 at 20:43
It is a common issue with LED lights strobing. The problem is in the lights driver circuitry and cannot be repaired easily. ( without electronic knowledge and tools.) The common cure is replacement.
  • Note that in a rental (at least in the US), replacement must be done by a licensed electrician, not the landlord or tenant.
    Commented Feb 9 at 22:00
