We noticed our bathroom counter is starting to crack and wanted to know if there is some sort of good glue for this. I think in the future it’ll need to be replaced but want to make sure it does not just fall right now.
enter image description here enter image description here enter image description here enter image description here enter image description here
  • looks like a piece of natural stone used as a topper on a pony wall as the base for a 1/2 glass wall. someone probably put too much weight on it and it has an overhang. need more pictures from other angles to give suggestions. Feb 8 at 2:11
  • Thank you! i added some more pictures, i thought this was a tile i am not 100% sure what it is.
    – Vincent
    Feb 28 at 16:27
The trick with glues is that you want something with the same properties as the substrate material. For stone tile, you need something with stone-like properties, e.g. grout. You only need a tiny bit and it's sold pre-mixed. In my experience, siliconized acrylic grout works best for this sort of patch-up work.
  • Should i try to use a toothpick to push it downwards into the crack? also the grout will be white? Edit: never mind i see they have different colors
    – Vincent
    Feb 28 at 16:49
    Grout has a relatively low tensile strength, so it's not going to repair this at all. It'll look nice, but it won't prevent further separation.
    Feb 28 at 16:51
    If you really want something solid -- tinted epoxy is (entirely too much of) a Thing...
    – keshlam
    Feb 28 at 16:54
    Neither the regular grout, epoxy grout or siliconized grout are going to fix the problem in terms of adding structural strenght. It is just a cosmetic fix while the stone is replaced.
    – Cheery
    Feb 28 at 18:33
