I wanted to find out if I can remove this wall?
upstairs floor plans
Wall to remove
    How do you know it is load bearing? Which direction are the trusses or roof members running?
    – matt.
    Jan 31 at 10:50
    Load bearing walls are usually supported from the bottom of the house with beams or walls. They also go across joists/trusses, not parallel with them. Any wall can be removed. Load bearing walls need a structural engineer to design the removal and new supports
    Jan 31 at 12:29
    I’m voting to close this question because a Structural Engineer is required to safely and accurately make this determination. Lives depend on this being accurate and it shouldn't be entrusted to well meaning random strangers on the internet.
    Jan 31 at 13:28
You can remove any wall.
Sometimes your house falls down if you don't first deal with supporting the loads the wall was supporting.
Since this appears to be part of a larger building(?), making parts of it fall down would probably result in people other than you being inconvenienced, and they would probably take legal action against you, so you apparently have twice the usual reason to consult a professional engineer licensed to practice in your locale before commencing destruction.
