I am planning to install an antenna on the gable at one end of a house. The electrical service panel is on the other end of the house, about 100 ft away. I plan to install an earth ground outside and right below the antenna. I now need to bond that ground to the electrical service panel ground. This bonding conductor will be 6 AWG copper bare wire, run through the house‘s crawl space. Many people seem to run bonding conductors outside the structure: I am presuming it OK to run this through a basement or crawl space?
Furthermore, the service panel is on one wall of a garage, and the bonding conductor's path through the crawl space meets an opposite wall of the garage. Concrete sidewalk surrounds the walls of the garage not attached to the house, like an apron.
Question: can I route the bonding conductor up the wall and into the garage‘s attic, towards the service panel on the opposite wall? Or should I saw-cut the concrete sidewalk and emplace the bonding conductor inside? The service panel is distant from the municipal water connection, so they appear to not be connected, so cold-water pipe bonding is not an option.
