For context, I'm a musician. I have a large workstation desk that, when outfitted with all my equipment, clocks in at 219 pounds. (I could probably get that down to maybe 205).
The legs/feet are oddly designed. The two front feet are 16"x5/8", and the two back feet are 2"x1 1/4". Right now the surface area of all four of those feet come in at 25in sq. That would be 8.76lbs per square inch. The desk is currently on carpet on a concrete foundation so no worries at all about the weight.
Now, I'm wanting to move into a shed we have but I'm worried that these odd feet dimensions will have two small of weight distribution for the floor.
The shed floor has joists every 12", 23/32" cdx plywood, then pergo gold underlayment and the top is pergo timbercraft laminate flooring coming in at 12mm (10mm plank and 2mm pad). In order to center the desk, the feet land exactly between the joists. Of course the joists couldn't perfectly be where i need them, right??
What're your thoughts on this? Possible? Or will the floor bend over time in those areas where the feet are in contact with the ground? (This would look clunky, but I've thought about potentially getting oak 2x4s and bolstering along either side of all 4 feet, sistering them together so as to add an additional 108in sq to the desk feet surface area, totaling 133, which would then distribute the weight as 1.65lbs per square inch. Though it still doesn't change the fact that the weight is going directly on board between joists.)
Thanks so much in advance for sticking with this tedious read and providing any thoughts or ideas for me!
