I'm trying to replace my 2 gang 2 way light switch with a smart one and getting completely lost in the current wiring and adapting it, I can't figure out why com would connect to L1 or find any examples of it online. Everything is COM-COM. Help identifying the current wiring would be extremely useful
Current switch wiring: enter image description here
New switch wiring:
Raw wiring enter image description here
Current switch enter image description here
**Other side of the 2 way enter image description here
  • Can you get us a pic of the back of the actual switch, focused enough to be able to read the labels? Not that I doubt your drawing, but, well, I've been known to work based on what I think I see, not what's actually there...
    Commented Jan 26 at 21:33
  • @FreeMan I've added a picture of the current switch, thanks! Also updated the picture with wires in Commented Jan 26 at 21:41
  • Was hoping for a better angle of the "Raw Wiring" pic... Also, why does the "New switch wiring" show Neutral (blue) connected to L1, L2, L3 Line connection points? That seems like a recipe for a dead short and a breaker trip. I'll back out of this now, because I really don't understand anything at all about UK wiring, sorry I can't be of more help...
    Commented Jan 26 at 21:46
  • Can you get diagrams/pictures of the other 2-way switch & the ceiling rose[s]. Someone's taken the time to tag two of the wires, but it would be nice to know where they go… because as it stands it doesn't make a lot of sense to me either:\ BTW, unless it's a relatively new build, UK light switches don't have a neutral - it's in the ceiling.
    – Tetsujin
    Commented Jan 27 at 10:53
  • @Tetsujin I've added a photo of the other side of the 2 way switch, but the roses (2 on one switch, 1 on the other for both switches) are so high up I couldn't get to them. The other switch is an absolute rats nest so I hope you can help me! Commented Jan 28 at 12:35
Disclaimer: these are only guesses based on common wiring practices
It looks like your switch has one wired for 2-way operation and one for simple operation.
As per your top diagram:
  • Left switch COM: This is your incoming live wire
  • Left switch L1: This is the power out to the light on the 1-way
  • Right switch COM: Traveller to the other end of 2-way
  • Right switch L1: Traveller to the other end of 2-way
  • Right Switch L2 Black: Traveller to the other end of 2-way
  • Right switch L2 Brown: This is power out to the light on the 2-way
The 2-way circuit has been wired with the 'modern' style (https://www.sparkyfacts.co.uk/Wiring-Diagrams-Two-Way-Lighting-Circuit.php)
Your new switch wiring diagram looks to only allow for 1-way wiring, if you are happy with losing the 2-way switching, then connect as follows:
  • the brown wire from the left COM to your new switches L
  • The brown wire from the left L1 to your new switches L1
  • The brown wire from the right L2 to your new switches L2
I would advise caution though because the other side of your 2-way is much more complex and I may be wrong.
  • The smart switch also has a neutral in which it requires for power, what would I do with this? Commented Oct 3 at 19:18
  • Connect it to the terminal block with the other neutrals. Commented Nov 27 at 19:17
