I am working on slowly updating my house with new wiring and I have a question regarding proper circuit setup.
My house has 2 stories and currently, I work on the second-floor guest bedroom. There are 3 bedrooms on this floor (A main bedroom, a guest bedroom, and an office).
I understand that ideally I should have 2 circuits for each room - one for light and one for outlets, but that would take up a lot of space in the panel.
Is it OK to wire each room as if they have 2 circuits, bring all 6 circuit wires back to panel, and then combine them before connecting to the panel?
So let's say I have the main bedroom outlet circuit, the office outlet circuit and the guest room outlet circuits meet near the panel, their neutrals, hots, and grounds joined together and then from each pigtail to the panel itself, effectively making all 3 a single circuit with a single breaker.
This way, should anyone ever need to have a lot more dedicated power specifically in the office they can disconnect office outlet wires and add a dedicated office outlet breaker.
Is that safe and OK to do?
Thanks!
