I recently found a crack in the material that seals the tile to the tub edge, so I removed it in preparation to replace it. I originally thought that the edge was filled with grout, but in trying to remove it I found that it was soft, but its also rough like grout. So now I am a bit confused about what to replace it with.
Ideally we would like to replace with the same grout/caulk mixed stuff that I am removing, unless that is just not the right stuff. I have also heard from the above post that I want to use silicone caulk but I think that might be smooth and not ideal as far as looks. I also found this sanded silicone grout which I am kinda leaning towards https://www.amazon.com/Color-Matched-Colorfast-Sanded-Sandstone/dp/B00X66X2D2.
Anyone have an idea of what the stuff I am removing is and if it is the right material to replace with? If not is there something I can use that still has that rough grout like finish? Or do I have to use silicone caulk? Thanks for the help, I just dont want to have to repeat this in a couple weeks...
