I have a propane fireplace I haven’t used in about 2 years. We just had the propane tanks filled, the valves on the tank are open. Also the valve on propane line coming into the house is in the on position. The pilot ignition sparks however I don’t smell propane and the pilot will not light. Any thoughts or suggestions?
I live in Pennsylvania so weather has been cold, but I also tried starting it in the fall before cold hit with no luck. Nothing else hooked up, just fireplace.
