Can I use 3/4" MDF platform that is 27" x 27" as an intermediate base platform between a washing machine that will be grounded to the MDF platform at the 4 corners by the leveling legs. And, below the MDF platform, will be 4 vibration damping spring posts at the same corners resting on top of the ground floor.
Thus, the MDF will just be a sandwich filling transition between the leveling legs of the washing machine and the spring damper posts below.
  • 4
    MDF is not the material you want to use. 3/4 plywood is preferable.
    – RMDman
    Commented Jan 14 at 16:27
I'd want to look at the details of the tops of the spring posts, how they attach to the shelf, and whether they can be positioned directly under the machine's feet.
But MDF really doesn't like getting wet; even repeated slight wetting is going to degrade it over time. And there are sometimes drip around washing machines. So I'd use a more water-resistant material, probably with a waterproof surface finish as well.
If the height of the posts is more than a few inches, cross-bracing will be necessary given that it's a heavy moving load.
  • I added a picture of the 4 spring posts that will be positioned directly below the machines feet. I thought of potentially using double ended bolt and threading them directly into the machine replacing the leveling legs, but the thread size is just very slightly different Commented Jan 15 at 17:46
  • I would find bolts that fit and skip the MDF
    Commented Jan 15 at 17:50
  • @FreeMan assuming the original feet can be fully removed without major dismantling (i.e. they're not captive) I probably would too. "Very slightly different" is quite likely a metric/imperial thing
    – Chris H
    Commented Jan 15 at 19:24
