One room is 1-1/2" lower than the next room. I suspect the room was an add on.
I’m trying to figure out the best way of not having that 1.5” drop. All the transition pieces don’t go that big. I considered 1” or two 3/4” plywood on the concrete on top of a vapor barrier to prevent concretes natural moisture but the plywood wouldn’t be secured. The plywood would be cheaper than pouring concrete to match.
I've removed the flooring in both rooms are already down to the concrete.
Any ideas?
