I bought a dimmer switch that is digital and it is a remote switch. Come to find out you need a master switch to run two dimmer switches to one light. The only way to get the master switch is to buy the combo kit. $60 + dollars and I already have a remote switch. Bought a single pole paddle switch and it works. (Paddle switch doesn't have a dimmer). The remote switch with the dimmer does not work. Are the two switches compatible?
2Without brand/model our guess is probably less accurate than yours. I'm going with "sure, why not?".– FreeManCommented Jan 9 at 12:04
2Can you provide make/model information?– ThreePhaseEelCommented Jan 9 at 12:48
1Definitely needs more information, but I'm going to say "no" - simple single-pole paddle switches are unlikely to be compatible with 3-way digital dimmer switches. Ideally you need proper 3-way (or 4-way?) pre-existing switch wiring, possibly also including neutral in at least one of the switch boxes. The manufacturers of the switches will tell you how to install and use them properly - it's not only difficult to ignore their instructions and set it up yourself, it could be dangerous and violates the safety ratings.– Fredric ShopeCommented Jan 9 at 14:33
Warning, the dimmer also has to be compatible with the light, especially if its LED.– Rohit GuptaCommented Jan 10 at 2:05
1 Answer
If you have 2 switches controlling one light, most likely you have a "3-way" as the Americans call it.
In a 3-way wiring topology, you do not get to choose the location of the smart switch/dimmer. That is dictated to you by the wiring in the walls.
So the usual problem in cases like yours is that you are trying to install the smart switch/dimmer in the wrong location.
Sometimes the arrangement is a "switch loop" with power to the lamp, and you have no ability to install a smart switch or dimmer which requires neutral. In that case, your option is to add /3 cable between lamp and the switch the lamp is cabled to. Or rearrange the wiring so power supply comes from a switch.
