I have a flat in a new building and I want to install AC. The construction company has already installed the lineset for a multisplit system. These are brick walls, covered with plaster and finished with paint.
When the AC technicians came, they did a test for leaks and a test for crushed lines. For the crushing, they had some kind of very flexible cables with different diameters. They stuck a cable in the line, and if they couldn't push it through, they tried a smaller diameter.
Their verdict was that the line is fine in one room, but improperly installed in the second room. They told me they need to break up the wall, replace some length of the refrigerant line, then I have to have the wall repaired (which will likely show up, since the wall is already finished) and then I can call them again to mount the AC.
I called the construction company and they will be sending somebody to check the problem. I would like them to replace the line and refinish the wall free of charge. The AC technicians warned me that they encounter this problem frequently, and the construction companies tend to deny there is a problem. Apparently, they usually test by having somebody blow air through the line, and declare it good enough. The AC people warned me that the reduced pipe diameter will be a problem for the AC running properly, and said that their company won't install an AC on crushed pipes.
So my plan is now to be able to demonstrate to the construction company person the problem with the pipe. Ideally, I'd get the same tool (cable?) and have it handy so the problem is obvious.
My question is: what is this tool? I don't want to purchase some random cable, which may be the wrong diameter, or not bendy enough. I suppose it's not purpose-built for AC testing, but I don't know what it's called and what's the original purpose, so I don't know what to look for, and where to go to search for it (hardware store, electricians', somewhere else)? My best description is that it looked like a small-diameter rubber tube, but I suppose it must have been solid inside, so it won't get squished itself when encountering the crushed place in the pipe. At the same time, it was much more flexible than a copper (electric) cable with rubber insulation.
