My condo is in an 8-story concrete and steel building, built mid-80’s in Massachusetts. My ceiling is 1/2” drywall screwed into 2-3/4” x 7/8” steel studs (Joists? Furring strips?). Those are hung with wire from the steel beams that support the cement floor above. The beams are 4 feet apart and the “studs” are 2 feet apart. (Photos of this at end of post.)
I’ve had no issue hanging light-weight swag lights using toggle bolts into the drywall. But I’d like to hang several heavier items at various points across the ceiling in front of my balcony door/windows. Static loads only: plants, plant shelves with 4-6 6-10" pots, grow lights, etc. I’m guessing some of these would be about 25 lbs eachI also want flexibility to move things around and reposition them as needed.
Here’s the area I’m referring to:
Photos inside my ceiling (over some closets where I have access).
I'd love to add supports above the ceiling, but at this point I do not want to cut into the drywall. The only access into the ceiling where I need to hang things is possibly where the 4" recessed lights (not shown in photo) and HVAC registers are. I haven't actually tried it. I also don't own the beams and concrete above the studs, so technically shouldn't use them.
I could just put a bunch of toggle-bolts all over the ceiling into the drywall and/or studs, but I assume that wouldn’t be strong enough for heavier things.
I've gotten some opinions/advice from various folks, but I’d love some additional expert advice. The consensus approach seems to be to surface-mount wooden supports, perpendicular to and spanning 2 studs, then attach hooks etc. into that. Questions:
- Does this sound strong enough?
- If so, how much weight do you think each board could support?
- If not, what would you suggest?
- Could I use 1x6 boards instead of 2x4s? 1x3s or 1x4s?
- Would I need a hardwood like oak or maple, or could use pine or poplar?
- What about PVC or vinyl boards?
- Could I use something like slotted angles or slotted square tubing instead of wood?
- Would self-tapping sheet metal screws be the way to connect to the studs, or would drilling and using toggle-bolts bet better?
- Should I also attach to the drywall itself with toggle-bolts?
- Would snap-toggles be best?
- I could extend the boards to the narrow bit of wall between the balcony windows and the ceiling and add shelf brackets or angle braces from the board to the wall. Would this add any useful support?
I also have a crazy alternative that would be a much bigger project: Building a minimal support structure around the window area from floor to ceiling. No idea what low-profile material I could use, but the basic idea:
- A leg on each side, from floor to ceiling, secured to the wall, with a cross piece connecting them along the ceiling. I guess this would also be screwed into the drywall and studs?
- Angle braces above the windows adding support and stability to the cross piece.
- Supports from the cross piece extending out a few feet, also secured to the studs through the drywall. I would hang the plants etc. on these.
Thanks for any advice, warnings, or additional ideas!
Here is how my ceiling is constructed, over some closets where I have access (additional ceiling photos):
