I will be installing a SunTouch heated floor for 200 square feet of space. I will wire this at 240V using a double pole breaker. The specs on the website indicate the amperage draw is 10 amps for the 783 feet of heating cable. This will be a dedicated line used for only the under floor heating system. Also, the line running from the heating system the panel will be around 25 feet.
1.) Should I use a 15, 20 or 30 amp double pole breaker? The specs page indicates that the maximum circuit load is 20 amps and 15 amps with a a SunStat control (which I have.)
2.) What is the smallest wire gauge I can use? Based on some other research, it seems like 8 gauge is the way to go.
