Happy New Year, All! I'm close (I think) to wrapping up an attempt at a built-in closet, but am having trouble figuring out a way to cover up two floor positions that were exposed when I removed part of the pre-existing closet wall (see pictures).
I am exploring the use of a wooden threshold (see in pictures - not stained yet), but wanted to see if the community had any other ideas.
Thanks a lot!
    Simple, easy, and should look good. Why make more work.
    Commented Dec 31, 2023 at 16:29
  • Threshold good. If it was somewhere other than a closet, I’d want to consider the bigger picture… Commented Dec 31, 2023 at 18:27
    For this question from what I see, you can make your solution as a answer. Quite right to answer your own question.
    Commented Dec 31, 2023 at 23:10
  • Only other idea I could give is to steal boards from other closets or areas that are closed/covered up. Otherwise the threshold looks fine to me—or it will once you stain it to match(ish) the floor.
    – Huesmann
    Commented Jan 2 at 19:20
