I remodeled a house a few years ago with a propane-fired Vitodens 100-b1KA Combination boiler/tankless hot water, but I got tired of the inconsistent hot water temperature and the exhaust venting into the backyard during during the summer when children are playing outside. I then installed a A.O. Smith Signature 900 50-Gallon HPS10-50H45DV Heat Pump Water Heater. This achieved consistent temps and no stinky exhaust, but I ended up with energy use 5x higher then Energy Guide estimates and ran out hot water on heavy use days.
SO: I have two modern, "energy efficient" hot water heaters that don't quite meet my needs. Can I combine the two to work together? Ideally I would like the heat pump to do most of the work and have the tank-less water heater fire up when the heat pump's hot water is depleted. Has anyone tried a combination like this before? Will my tank-less water heater suffer for being fed preheated hot water?
