We've got a Carrier Infinity, 2 stage, high efficiency furnace.
I noticed water on the floor just underneath the furnace, and can hear a metallic dripping sound. When I opened it up, I do see water dripping at the very back of the bottom of the furnace.
Is this something I can fix myself? Or do I need to call HVAC repair? And if so, what is (most likely) wrong and how much will it cost me?
I checked, its not the condensate tube that leads to the pump (which has given us issues in the past)
    If "it's not the condensate" (one of the 3 lines, or the stupid little drain box thing itself), then you've a problem. "Water on the Floor - If moisture has buildup on the floor at the foundation of your furnace, then the most probable cause is a cracked heat exchanger. While leaking water is common in high-efficiency furnaces due to the condensation process, it’s rare in standard-efficiency ones." andersonair.com/8-symptoms-of-a-cracked-heat-exchanger - There's a working CO detector in the house, right?
    – Mazura
    Dec 27, 2023 at 23:15
  • Do you have a humidifier installed there at the furnace?
    – Greg Hill
    Dec 28, 2023 at 0:12
Most likely causes are leak in the condensate or you have high humidity in the room and your house air is condensing on a cold portion causing the drips. Both should be fixable with some level of DIY skills.
