I want to put my internet router into the loft and then use multiple Ethernet cables from it that are dropped to every room and Wi-Fi access points. I live in the UK.
The network provider has a socket at the ground floor and the router is connected into it at the present time. In order to move the router to the top of the house, I need to have an ethernet cable that is going to connect from bottom of the house to the top.
I believe that doing the cable vertically from the living room, into its ceiling, out of the 1st floor bedroom, into its ceiling, out of the loft floor (between joists), is probably the shortest and best path. Do you agree?
What I need to know is, how hard is to to create a groove inside the walls of the living room and bedroom (masonry walls) for the cable going from living room up to the loft? How large should the grooves be? Is some sort of canal required to contain the ethernet cable? and how will they be filled in once the cable has been installed?
