I am planning to replace the anode rod on my water heater. Since I only have 19" of clearance to work with, I need to use a flexible replacement.
Looking at the available products, most have segments connected by steel cable. Wouldn't that exposed steel cable act as a cathode - providing a shortened galvanic electrical path to the attached anode material? I would think this would both reduce the protection of the tank and accelerate the corrosion of the anode.
Is this a concern? Is it worth looking for alternatives that do not expose the steel cable?
