This needs to carry a huge 77 inch TV. There are 4 screws like that. However, while trying to put the tv on the mount I managed to get it stuck in a weird way and the dowel broke out the wall and left a huge hole.
Can I somehow repair this whole and use it again? I don't want to move the TV elsewhere. Or should I just make two more holes in the middle of the mount and leave the corner alone?
How important is it to have lots of space between the dowels?
Can I use foam or simply mix gips to plug the whole and then just put a new dowel there?
This is how it looks:
This is the dow (rigips type):
The mount outer holes are about 37cm width, 10cm height.
Currently it looks like this, with only one side to the stud, hope thats reasonably safe?
